BPO Bulletin
Why Software, Automation and AI Don’t Create Intelligent Operations on Their Own
The Technology Isn’t the Hard Part
The first articles in this series focused on visibility and understanding. Before an operation can become intelligent, leaders need a reliable view of how work is actually being performed. Once they have that view, they still need enough operating context to understand why performance is changing and what is likely to improve it.
Technology can help enormously with both. Systems can capture signals that were previously invisible. Automation can remove repetitive work. Analytics can identify patterns across large volumes of operational data, and AI can work across structured and unstructured information, investigate exceptions and increasingly recommend or execute actions.
The harder issue is what happens around the technology. An organization can deploy a capable tool, automate a meaningful amount of work and still see only limited improvement in the overall operation if the surrounding process, roles, measures and decisions remain largely unchanged.
BCG's 2026 AI at Work research illustrates the point. Among frontline employees who regularly use AI, 42% said they were saving at least eight hours each week, roughly the equivalent of a full workday. Yet 66% said they received limited or no guidance on what to do with the time they saved, and more than half were not reinvesting that time in more strategic work.
For an operations leader, that difference matters. Saving time on a task creates capacity, but capacity only becomes value when the organization decides what to do with it. The same team might handle more volume, improve service, take on different responsibilities or eventually operate with a different staffing model. Without some deliberate change to the work, however, the productivity gain may remain largely theoretical.
When Better Technology Meets the Same Operation
Consider a document-services operation receiving work through email, web forms and several customer-specific channels. The organization introduces technology that classifies incoming requests, extracts information and routes standard transactions into the appropriate workflow. Routine work begins moving faster, manual entry declines and employees spend less time sorting and routing requests.
Several months later, overall turnaround time has improved far less than expected, even though the technology itself is performing as designed. A meaningful share of the incoming work still arrives incomplete or in formats the standard workflow cannot handle. Those transactions move into exception queues, where different teams manage them differently. Some employees resolve issues immediately, while others send an email and wait for additional information. One group has created its own spreadsheet to track unresolved requests, and a legacy intake channel that was expected to disappear is still being used.
The new technology has improved the standard path, but many of the conditions surrounding that path remain unchanged. Reducing turnaround time now requires more than another technical improvement. The organization has to examine why so many exceptions occur, whether every intake channel is still necessary, how ownership should work once a transaction leaves the standard workflow and whether the process itself needs to be simplified.
This is a common source of disappointment in transformation programs. Improving one part of a process can generate a real benefit without changing the economics or performance of the process as a whole. In some cases, the improvement simply makes the next constraint easier to see.
Assess Your Intelligent Operations Maturity
Automating a Process Is Different From Redesigning It
Much of automation begins with the work as it exists today. A manual activity becomes digital. Information that employees once transferred between systems moves automatically. A routing decision becomes rules-based, or a repetitive activity shifts from a person to software.
Those improvements can be worthwhile without addressing whether the process itself is still appropriate. An unnecessary approval can be automated and remain unnecessary. A workflow with too many handoffs can move information through those handoffs more quickly. An inefficient exception process can become faster without addressing the conditions creating the exceptions.
This distinction becomes more important as organizations move beyond traditional automation into generative and agentic AI because a much broader range of work can now be reconsidered.
Accenture drew on more than 2,000 generative-AI projects and surveys of more than 3,000 C-level executives and found that only 36% of executives said they had scaled generative-AI solutions, while just 13% reported significant enterprise-level value. Its research points to a different approach among organizations generating greater value: they were more likely to tackle core business problems through end-to-end process reinvention, aligned leadership, measurable goals and work redesign.
The opportunity, then, extends beyond identifying tasks that technology can perform. Organizations can use the expanding capability of AI and automation as a reason to reconsider how the work should be designed in the first place.
Productivity Gains Still Have to Be Converted Into Value
The BCG finding on time savings exposes an operational issue that will become increasingly important as AI adoption spreads.
If someone saves eight hours each week by using AI, those hours do not automatically show up as lower cost, higher throughput or better service. They represent capacity that the operation can now use differently.
In an environment with growing demand, that capacity may allow the existing team to absorb more work without adding staff. In a service operation, it may create more time for exceptions, customer interactions or higher-value activities. Roles may be broadened as routine work declines, or work may shift between positions as the balance between people and technology changes.
BCG's research found that companies moving beyond simple tool deployment and using AI to reshape workflows end to end were generating stronger results across measures including value captured, employee experience and time saved. The distinction matters because it shows that the benefit does not come only from making the individual task faster. It comes from redesigning how that saved time is used across the operation.
Operations leaders therefore need to be able to see where capacity is being created and determine how it should translate into an outcome. Otherwise, an organization can legitimately report large productivity improvements at the task level without seeing the same improvement in the performance of the business.
Point Solutions Improve Pieces of the Work
Technology is usually purchased to solve an identifiable problem. A scheduling application improves workforce planning. A workflow platform manages intake. Automation removes a repetitive activity. An AI assistant gives employees faster access to information.
Each system may perform exactly as expected, while the operation itself continues across the boundaries between them. A customer request might begin in one system, move through another, encounter an exception outside both and eventually require someone in a different function to make a decision. Where those systems do not connect cleanly, employees often fill the gap by transferring information, reconciling differences, following up on missing inputs and deciding what to do when the workflow reaches an unanticipated situation.
Over time, an organization can accumulate sophisticated technology while still relying heavily on email, spreadsheets and individual experience to keep work moving. The applications have improved, but the operating model connecting them may not have changed nearly as much.
Accenture's research on operating models provides some context for the scale of that problem. Ninety-four percent of the C-suite executives it surveyed said their current operating models were jeopardizing growth and performance, and 74% believed they needed to be completely rethought to become more resilient.
That is why Intelligent Operations cannot be approached as a collection of technology projects. The operation has to be considered across the points where systems, functions and people intersect, because those boundaries are often where delay, manual effort and ambiguity remain.
AI Makes the Operating Model More Important
Traditional automation generally worked within relatively clear boundaries. A condition was met, a rule was triggered and an action followed. AI agents can operate across a much broader part of the workflow by interpreting information, making decisions, initiating actions and coordinating multiple steps.
That potential also brings operating-model questions much closer to the technology itself. If responsibility for a process is fragmented across several functions, someone still has to define where an agent can act. If different parts of the organization use conflicting definitions or policies, the technology has to navigate those differences. If one team owns the data, another owns the workflow and another owns the customer outcome, introducing an autonomous system does not remove those boundaries.
Organizations also need to decide which decisions can be delegated, which require review, how low-confidence situations are handled and who remains accountable when automated actions cross several parts of the business. Governance, in this environment, becomes part of operating design rather than something added after the technology is deployed.
Deloitte's 2026 research on agentic transformation found that fewer than half of surveyed leaders considered their organizations ready for agentic AI across most areas of the business, with workforce and business processes among the weakest areas. At the same time, 74% expected nearly half of their business processes to be redesigned or rebuilt around AI agents within four years. Deloitte also identified the lack of a unified data foundation, difficulty governing agents and integration complexity as significant barriers to scale.
The gap between those ambitions and current readiness is significant because the future of AI in operations will not be limited to employees using better tools. It will increasingly involve technology participating directly in how work is coordinated and decisions are made.
The Work Has to Change With the Technology
Organizations beginning to capture more value from AI are increasingly treating the operating model as part of the transformation. That requires looking beyond whether a particular application works and understanding what its introduction changes elsewhere in the operation.
Processes may need fewer steps because some activities no longer add value. Roles may change as routine work moves to automation and employees spend more time handling exceptions, judgment and customer needs. Performance measures may need to evolve because counting transactions or hours no longer captures how work is divided between people and technology.
Management practices also have to adapt. Leaders need visibility into where automation is succeeding, where exceptions are occurring, how much capacity has been released and whether that capacity is producing the outcome the organization expected.
Deloitte's 2026 Global Technology Leadership Study found that 81% of surveyed technology executives believed their organizations could deploy and govern AI at scale, yet nearly three-quarters also said their operating models would need to change within the following 12 to 18 months to sustain that progress. The changes identified in the research extend into decision rights, governance, workforce design, funding and accountability.
For Intelligent Operations, this means people, processes, data, technology and controls have to be considered together. Technology may provide speed, intelligence and scale, but the surrounding operation determines how those capabilities are used and whether they ultimately improve performance.
Pilots Prove the Technology. Scale Tests the Operation.
Pilots are valuable because they give organizations a controlled environment for determining whether a new capability works and whether there is a plausible path to value. The problem is that pilots often benefit from conditions that do not exist at scale.
The use case is clearly defined, the participants are engaged and leadership attention is high. Data problems receive direct attention, integrations have dedicated support and exceptions can be resolved quickly by the team running the initiative.
Scaling introduces the variation that the pilot was able to limit. Sites may operate differently, customers may have different requirements and data quality may vary. Local teams may have developed workarounds that were never formally documented. Legacy systems remain because another function still relies on them, while measures and incentives may continue to reward behavior designed around the old process.
Once those conditions appear, the challenge extends well beyond technical performance. The organization has to decide how much process variation it will continue to support, which practices should be standardized, how roles should change and how results will be measured consistently across a larger environment.
Deloitte's agentic-AI research reflects this broader readiness challenge. Even among organizations already experimenting with or deploying agents, workforce, process, data, governance and integration issues remain central to moving from isolated use cases toward more coordinated operational models.
The transition from pilot to scale therefore tests whether the organization is prepared to operate differently, not simply whether the technology is capable of doing what it demonstrated in a controlled environment.
Intelligent Operations Start With the Outcome
A different approach begins with the performance of the operation rather than with the availability of a technology.
Leaders can start by identifying where unnecessary effort, delay, variability, cost or risk is being created, where service outcomes are being affected and which parts of the workflow generate repeated exceptions. They can also look for places where technology has already created capacity but the operating model has not yet been adjusted to use it effectively.
From there, technology becomes one of several possible interventions. Automation may remove repetitive work. Better information may allow someone to make a faster or better decision. A workflow may need to be redesigned, an unnecessary step eliminated or an agent given responsibility for resolving a defined class of exceptions. In other cases, the best solution may involve staffing, process discipline or a change in how the work is managed rather than another technology deployment.
This is also the logic behind Measure → Analyze → Improve. Technology can expand the range of signals an organization can measure, AI can accelerate analysis and increasingly help identify likely causes, and agents can participate in recommending or executing interventions. The operating discipline comes from connecting those capabilities to an outcome, measuring whether the intervention worked and using what was learned to improve the next decision.
Over time, successful and unsuccessful interventions both become useful operational knowledge. A solution that works under one set of conditions can inform another location or process, while a failed intervention helps narrow the response the next time a similar pattern appears. The operation becomes more capable because it retains and applies what it has learned rather than repeatedly starting from the beginning.
From Technology Deployment to Intelligent Operations
Canon Business Process Services works at the intersection of people, process and technology. Our Intelligent Operations capabilities help organizations connect operational signals with an understanding of how work is actually being performed, identify where performance is constrained and determine which interventions can produce measurable improvement.
Those interventions may involve automation, analytics, AI or process redesign, but they may also require changes to workflows, staffing, roles, decision rights or the way performance is measured. The objective is not to maximize the amount of technology inside the operation. It is to apply the right combination of capabilities to improve the outcome.
For organizations managing complex workplace, document and logistics environments, that means looking beyond individual tools and examining the operating system around them: how work moves, how exceptions are handled, where capacity is being created, how people and technology share responsibility, and whether improvement can be sustained over time.
Contact Canon Business Process Services to learn how our Intelligent Operations capabilities can help translate technology investment into measurable operational improvement.
As technology becomes more capable and easier to deploy, the remaining constraints become increasingly visible. Processes have often evolved over years, knowledge is distributed among individuals and sites, ownership crosses organizational boundaries, and improvements that work in a pilot can be difficult to sustain across a larger operation. Those conditions explain why Intelligent Operations cannot simply be installed, even when the underlying technology is ready.
Canon Business Process Services helps organizations turn technology into operating improvement by connecting people, processes, data and technology around the work itself. Through our Intelligent Operations capabilities, we help clients identify where performance is constrained, redesign how work gets done, apply automation and AI where they create the greatest value, and measure whether those interventions actually improve the outcome. If your organization is investing in technology but not seeing the operational impact you expected, we can help you understand where the gap is and what needs to change next.
