BPO Bulletin
Seeing the Operation Is Not the Same as Understanding It
In the last article, Before Operations Can Become Intelligent, They Have to Become Visible, we looked at a problem that remains surprisingly common across large operations. For leaders managing complex operations across multiple sites, teams and systems, getting a clear view of how work is actually performing remains harder than it should be. Data is spread across platforms and locations, measures are not always defined consistently, and important operating knowledge often sits in spreadsheets, local processes or in the experience of the people closest to the work.
Many organizations still struggle to get a clear, consistent view of how work is actually performing. Data is spread across systems and locations, measures are not always defined consistently, and important operating knowledge often sits in spreadsheets, local processes or simply in the experience of the people closest to the work.
Improving that visibility matters. It allows leaders to see where service levels are changing, where volume is moving, where productivity is falling and where one location behaves differently from another. But better visibility also exposes another problem. Knowing that performance changed does not necessarily tell you what caused it, and a poor diagnosis can lead to an intervention that adds cost without improving the operation.
That is the next challenge for Intelligent Operations: moving from seeing what happened to understanding why it happened.
The Same Performance Problem Can Have Very Different Causes
Consider two document operations that are both missing the same turnaround target.
At the first site, incoming volume has increased significantly over several weeks. Productivity per employee is relatively stable, error rates have not changed much and the process itself appears to be functioning normally. Demand has simply moved beyond the capacity available during certain periods.
The second site looks almost identical on an executive dashboard. Turnaround time has deteriorated by roughly the same amount, but volume has barely moved and total staffing is unchanged.
Looking more closely reveals a different problem. A new document type is entering the process more frequently. Employees are handling it inconsistently, exceptions are increasing and more work is being routed back for correction. Experienced employees are spending more of their time resolving those exceptions, which means reported headcount remains stable while the productive capacity of the team is falling.
Both sites have the same visible symptom, but they do not have the same operational problem. Adding capacity may be appropriate at the first site. At the second, additional staffing could simply increase cost while leaving the underlying process issue untouched.
This is where visibility begins to separate from understanding. A performance measure can identify where attention is required, but deciding what to do requires a much richer view of the operation around it.
Operations Are Systems, Not Collections of Metrics
Operational performance is rarely determined by one variable at a time. Volume affects staffing requirements, but that relationship changes with the mix and complexity of the work. Staffing matters, but headcount alone says little about skill, experience, scheduling or where people are positioned during a shift. Process design matters, but exceptions and rework can create additional effort that disappears inside aggregate productivity measures.
Physical conditions matter as well. Building layout, equipment availability, customer requirements, queue times, handoffs and local constraints can all affect an outcome that eventually appears as a single number on a dashboard.
Traditional reporting has to simplify this complexity. Leaders cannot manage a large operation by examining every transaction or every variable individually. The problem arises when the simplified view becomes the explanation rather than the starting point for investigation.
This is also why experienced frontline and operations managers remain so valuable. They often supply the context that formal reporting does not contain. They know when nominal staffing levels do not reflect the experience available on a shift. They understand which exceptions are unusual, which client requirements create additional work and which local conditions are affecting performance even though they never appear in the enterprise data.
When that understanding remains largely in people's heads, however, the organization becomes dependent on who happens to be available when a problem occurs. Intelligent Operations should make more of that knowledge available to the organization itself.
More Data Does Not Necessarily Create More Understanding
The natural response to incomplete visibility is often to collect more information. Sometimes that is exactly what is needed, but the amount of data available and the ability to understand an operation are not the same thing.
McKinsey documented a useful example involving a company that had spent several million dollars on a smart manufacturing system capable of tracking more than one million variables. When the company examined 500 data tags associated with a particular analytical problem, roughly half contained limited or duplicate information and another quarter were considered unhelpful. More importantly, the team discovered 20 critical variables that were not being measured at all.
The example comes from manufacturing, but the lesson applies much more broadly. An organization can collect an extraordinary amount of information while still missing the relatively small number of signals that explain an important outcome.
The better question is not how much data an operation can capture, but which information materially improves the ability to understand performance and make a better decision.
In workplace services, elevator delays may have a direct effect on internal delivery performance. In a logistics environment, walking distance, congestion or a particular handoff may be consuming capacity. In document operations, the type and frequency of exceptions may explain far more than total volume alone.
Those details become valuable when they help explain the result. Measurement therefore has to be selective as well as comprehensive. The objective is not to instrument every possible activity. It is to identify the signals that have meaningful operational value.
Understanding Requires the Process Around the Data
Knowing that productivity declined is useful. Knowing where additional time entered the process is much more useful.
A process can accumulate friction in many small ways. Work waits for an approval, moves through an unnecessary handoff, enters a queue, comes back for correction or encounters an exception that takes an employee outside the normal workflow. No single issue may look significant when viewed independently, yet together they can materially change cost, capacity and service performance.
This is why process context is becoming increasingly important as organizations rethink how operations are managed. Deloitte's global process-mining research found that organizations are looking to integrate process intelligence more deeply into their operations, while data quality, collaboration across departments and the difficulty of converting insight into measurable outcomes remain persistent barriers. The same research found that 25% of respondents were already combining AI with process mining and 74% planned to incorporate AI into future initiatives.
The direction is significant. Operational management is moving beyond periodic reporting toward a more continuous understanding of how work flows through the organization, where friction develops and which conditions are associated with better or worse outcomes.
That does not diminish the role of experienced operators. It gives them a stronger starting point. Instead of spending most of their time reconstructing what happened, they can spend more of it deciding what should change.
Better Diagnosis Changes the Intervention
The practical value of understanding becomes clearest when an organization has to act.
If performance declines and the assumed cause is insufficient capacity, the response may be to add labor. If the actual problem is rework, the additional employee may simply help an inefficient process absorb more waste.
If quality deteriorates and the organization assumes employees need additional training, it may launch a training program. If the underlying problem is incomplete information being generated upstream, that investment does little to correct the source of the errors.
A logistics operation may respond to declining throughput by changing staffing levels when the real constraint is equipment availability, congestion or poor sequencing of work. A workplace operation may add coverage when travel time or building access is consuming the capacity it already has.
In each case, the visible metric is real. The risk lies in acting on the most obvious explanation rather than understanding the system that produced the result.
The strongest operations teams have always worked this way. They look beyond the symptom, test assumptions and apply experience before deciding where to intervene. The opportunity now is to make more of that discipline systematic and repeatable across the enterprise.
An Intelligent Operation Has to Remember What It Learns
There is another gap that becomes increasingly important as organizations scale. Even when a team correctly diagnoses a problem and improves the process, much of that learning can remain local.
A site manager discovers why a recurring bottleneck occurs. The team changes the workflow, performance improves and attention moves to the next issue. Months later, another location encounters a similar problem and begins the investigation again.
The organization solved the problem, but it did not necessarily retain what it learned.
Intelligent Operations should make it easier to capture the relationship between the original signal, the conditions surrounding it, the likely cause, the intervention that was attempted and the result that followed. Successful interventions provide useful evidence, but failed interventions matter too because they narrow the range of possible responses the next time a similar pattern appears.
Over time, that creates something much more valuable than a library of reports. It creates operational memory. Experience generated in one part of the organization can begin to inform decisions somewhere else rather than disappearing with the people who originally solved the problem.
This is where Analyze within the Measure → Analyze → Improve framework becomes broader than traditional analytics. Measure establishes visibility into the operation. Analyze connects those signals to the process, the operating environment and what the organization has learned previously. Improve turns that understanding into an intervention and evaluates what happened afterward.
The loop matters because each decision has the potential to make the next one better.
The Future of Operations Will Require Context
This capability becomes even more important as AI moves further into operational decision-making.
PwC's 2026 Digital Trends in Operations Survey found that 83% of operations and supply-chain leaders expect AI agents and automation to accelerate the breakdown of traditional functional silos. Yet only 27% said AI was fully embedded across business units, and 37% were comfortable allowing AI agents to execute complete end-to-end operational processes.
Those numbers illustrate both the ambition and the gap. The future is likely to involve AI identifying patterns, investigating exceptions, recommending interventions and eventually taking on more responsibility for coordinating work. But that future requires considerably more than giving an AI system access to a collection of dashboards.
It needs enough context to understand what the data represents, how the process operates, which constraints matter and what happened when similar decisions were made before.
A 2025 Celonis survey of more than 1,600 business leaders found that 89% believed AI needs the context of how the business actually runs to deliver the expected results, while 58% worried that shortcomings in existing processes could limit the value AI creates. Celonis is a process-intelligence vendor, so the findings should be considered in that commercial context, but the underlying point is consistent with the broader operational challenge: data becomes more useful when it can be connected to the reality of how work gets done.
The move toward predictive and agentic operations therefore raises the importance of operational understanding rather than eliminating it. AI may dramatically improve the speed with which organizations identify patterns and investigate problems, but its recommendations will only be as useful as the operating context available to inform them.
From Visibility to Understanding
Our Intelligent Operations capabilities are designed around this progression. Canon Business Process Services brings operational data, process knowledge and performance signals together so organizations can move beyond knowing that something changed and develop a clearer understanding of why it changed, where intervention may be needed and whether that intervention produced the intended result.
For organizations that already have plenty of reports but still depend heavily on manual investigation and local experience to explain performance, this is an important next step. It creates the foundation for faster diagnosis, more targeted interventions and a growing body of operational knowledge that can be applied across sites and processes.
It also exposes the next challenge.
Better visibility and better analysis can dramatically improve operational decisions, but neither guarantees that the operation itself will change. Organizations have spent years adding software, automation and, increasingly, AI while continuing to struggle with fragmented processes, adoption and the ability to translate technology into sustained operational improvement. PwC's 2026 research found that 89% of operations and supply-chain leaders said their technology investments had not fully delivered the expected results.
The next phase of the Intelligent Operations conversation is therefore less about what technology can do and more about what has to surround it. Why do capable technologies so often produce useful tools without producing lasting operational change?
That question takes us beyond visibility and analysis, and into the operating model required to make intelligence matter.
Better visibility and better analysis can dramatically improve operational decisions, but neither guarantees that the operation itself will change. Organizations have spent years adding software, automation and, increasingly, AI while continuing to struggle with fragmented processes, adoption and the ability to turn technology into sustained operational improvement.
The next question is therefore not whether the technology is capable. It is why capable technologies so often fail to change the operation around them.
If your teams are spending too much time reconciling reports, explaining performance manually or solving the same problems repeatedly, there is an opportunity to create a more connected and intelligent way of operating.
Contact Canon Business Process Services to learn how our Intelligent Operations capabilities can help you improve visibility, understand performance and create a stronger foundation for continuous improvement.
